Hi users!
Just a quick question regarding visualizing the HB sensor grid, is there any way to visualize grid only? It would be very helpful when it come to validate the model in early stage ![]()
Thanks in advance!
Hi @zengwoo1028, If I understand your question correctly, you can turn off the visibility of the component and connect the points inputs to a preview or geometry component.
Hi @mostapha,
Apologize for the confusion.
These was no problem with previewing the sensor points as well as the mesh.
However, is there any way to preview the all of the sensor grids in all meshes? Hope this picture below could help you with the question. It would be very nice to check them before running the daylight simulation. Cuz, I’ve had a few times with after running few hours of simulation and found out some undesired results on heat map especially when it comes to non-rectangular surfaces.
Many thanks!
You can try natige GH components for that, like face boundaries or mesh edges.
Thanks for the help! The problem has been resolved ![]()
