VSC results above 40%
Greetings,
I am trying to analyse facades using the VSC method. I am using the SkyView component with clouded sky and ab- set to 1.
From my test case I get values above 40 %, from what I remember it should not be possible to exceed 40%.
I also get quite high values where the shading is fairly large, se the figure below and the attached script.
Does anyone know what might be the problem here? LB version 1.3.1.
Thanks!
Best regards,
Tobias
VSC_analysis.gh (54.8 KB)
It was missing the direction input, since the grid component uses Z directions when not defined.
Attached is the correct file.
VSC_analysis.gh (56.8 KB)
