Water-to-water heat pump with Ironbug
Could someone please provide an example file for a river source heat pump using the Ironbug plugin?
Hi @The-Ashok-Majhi, have you successfully prototyped this system in EnergyPlus or OpenStudio? If yes, I can help you to replicate it in Ironbug.
HI @MingboPeng, would you mind sharing the example file of a water to water heat pump please?
Thank you.
