I have been running into an issue where some ironbug components are returning an error 'Weak_ptr" especially the duplicate component. It seems to happen randomly
I can recompute, or reconnect a wire and the error goes away. But this causes big issues when I am using clusters and the error happens unnoticed within a cluster and part of the model is not being applied.
I have had this issue on multiple different files.
Is there a way to fix this issue or a work around?
Interesting, thanks for the info. I had been using this approach for other zone HVAC components but not for the outdoor air stream for some reason. I will try this approach and see if I get any issues. On another note, have you run into this issue before? is there something wrong with the configuration here:
