WebGPU Lattice Boltzmann CFD & Thermal. Early design. Need feedback!
Hi everyone,
I’m a 16-year-old developer and aspiring architecture student. Ladybug Tools has been my absolute gold standard for understanding environmental building design. Your ecosystem inspired me to dive deep into building physics.
While learning about CFD workflows (like Butterfly/OpenFOAM), I realized that while they offer unmatched accuracy, they can be too computationally expensive for the very first days of a conceptual sketch, where architects just need a quick directional intuition.
To explore a faster, lighter alternative for that specific phase, I built Polymère (AHI) — a building physics engine that runs entirely in the browser using WebGPU compute shaders.
The Technical Stack:
  • Takes an IFC model and runs a GPU-accelerated conservative voxelization pipeline.
  • Solves airflow using a custom Lattice Boltzmann Method (LBM D3Q19) written completely in WGSL.
  • Couples the fluid dynamics with a Conjugate Heat Transfer (CHT) solver to calculate buoyancy-driven flows.
  • Calculates thermal comfort (PMV/PPD) per ISO 7730.
I know perfectly well that a browser-based voxel solver cannot replace the rigorous RANS/LES models of OpenFOAM for final validation. My goal is strictly to provide instant, real-time feedback (~60fps) during early massing.
Links:
Live engine: https://polymère.com/
Whitepaper (math & equations): Polymère - Revealing the Invisible
My question to you (the true BPS experts):
Is there a place for ultra-fast, lower-fidelity WebGPU solvers in the conceptual design workflow? Or is the risk of “garbage in, garbage out” too high without proper meshing and traditional CFD?
I would be incredibly grateful if you could tear apart my methodology or test the UI. I’m here to learn from the best!
You can also text me directly: ilyatrofimov@polymere.press
Would love to learn more but both website links say that they cannot be reached. Is the link incorrect?
Hi @remyweather, thanks for letting me know! The issue is with the ‘è’ in the domain name which breaks in some forum parsers.
Try copy-pasting this raw link directly into your browser address bar: https://xn--polymre-6xa.com/
It looks weird because of Punycode, but it’s the exact same site. You can find the whitepaper by just adding /whitepaper to that URL.
I would absolutely love to hear your thoughts once you get it running! (P.S. If it still doesn’t load depending on your region, using a VPN usually helps. Personally, I use a France server).
