Dear All,
After replacing the honeybee_honeybee user object (due to the latest update regarding the therm gasses info) when I load the file I get an error message.
In addition, some components don’t recognize that honeybee is flying. This is fixed when I disable-enable those components.
Its not a fatal error but it certainly is a nuisance.
Wondering if someone else has had a similar problem.
kind regards,
Mauricio
dynamic_u_val_2.gh (501 KB)
Hi Mauricio,
This is because of the order of execution of components in Grasshopper. To solve the issue select Honeybee_Honeybee component and press Ctrl+B to send it back in the list and save the file. Next time that you open the file honeybee_honeybee will be executed first.
You can read more here.
Mostapha
I didn’t check the image that you attached. That happens since dynamic item-selector hasn’t select any items which happens because zone program couldn’t find Honeybee which is because the issue that I just explained.
Hi Mostapha,
Execution order fixed everything. Thanks. I’ll export the ghuser as soon as I’m done with a few things.
all the best,
M
