i can’t figure out why the radiation result that is always zero.
but if i switch the other computer. it work well.
it seem the problem is on the selectskymtx. it’s always turn to 0.
could anyone help me?
thanks in advanced.
thanks in advanced.
Keisei,
I’ll suggest two options (recently one of my students “suffered” the same thing):
Option 1: GO to the directory where the sky matrix is calculated (usually c:\ladybug, but check this in the output of the LB_LB component). Look for the directory with the weather station name (or so). You’ll see that the file is 0 size (probably). Delete it and try activating the simulation again.
Option 2: If 1 doesn’t work, define another target directory in the input of the LB_LB component.
Hope this will work for you.
but i’m still confused about check the output of the LB.
is seen in my picture? and how to delete the zero size?
and option2 seems to change a weather file location? such as from desktop to the other place?
sorr… i’m not familiar with grasshopper.
thank u very much!!!
Hi Keisei,
Can you try the attached file and let me know if it works. It basically does what Abraham mentioned.
Also can you share the weather file? Taipai_02_[Nowhere] doesn’t look promising! It might be because the values are missing from the weather file.
Mostapha
genSky_msr.gh (369 KB)
Thank u Mostapha!!
sure! i have attached the file.
but i have tired before. it’s seem works well.
thank in advanced!!
Cumulative_Radiation_Analysis_w_Ladybug.gh (406 KB)
Taipei.wea (138 KB)
WEA file is the Ecotect weather file format (also used for Daysim). This probably making you trouble. Try to use an EPW file.
Usually the EPW files size is about 1.5Mb. The file you attached is just 138 k.
fail…
it doesn’t work…
Keisei, You should provide more information for us to be able to help. You can download an epw file from different sources: http://www.grasshopper3d.com/group/ladybug/forum/topics/faq-where-t…
hi Mostapha!!
i have downloaded the wea file on your website.
and i try the Abraham’s file to use your wea file. but i fail again. i find someone seems has the same problem with me. and i try his method,it doesn’t work. here is the link.http://www.grasshopper3d.com/group/ladybug/forum/topics/radiation-i…
i have the key error too
thank u Mostapha!!
thank you abraham!!
i fail again, i click the unblock the file.
thank you for your time !!
thank u
Hi there Keisei,
I’ve read the whole thread by now, nothing in it can solve this problem. Thing is, I am in the exact same situation as you. the resulting graph of my radiation analysis is only a huge blue tone on my subject of analysis… everything shows up as 0 kWh/m2. I could work with the same files (.gh , .epw , and even .3dm) in other computers and its works perfectly fine, lots of detailed results come up.
I can use Ladybug for other analysis (drybulb temperature analysis mostly) in my computer and its working well… so I believe it isn’t a LB problem.
I am using a mac with windows 7 through parallels.
Were you able to solve this problem?
Otherwise, does somebody know a solution to this problem? It’s nightmare…!
thanks!
Hi Juan Pablo, Did you checked genmtx not to be blocked? Check this discussion: http://www.grasshopper3d.com/group/ladybug/forum/topics/radiation-a…
Hi,Juan Pablo
i am use the mac with windows 7 through parallels too!!!
parallels desktop 10!!
it seems the problem is the mac!
hahaha
Thank u Mostapha!!
i have tried to unblock the file. and it show the file that is unblock.
but it does’t work.
thank you
