Hi @chris I’ve got a problem through all my simulations with an error which is: 1. Solution exception:‘Room’ object has no attribute ‘orphaned_faces’
It happens even in the simple “room from solid” component.
You need to connect a model to the OS component. Right now you are connecting rooms, which are not accepted.
Dear, @AbrahamYezioro thanks for your help and the time taken to explain my mistake, problem is solved now.
Wish you the bests,
