Hello!
I’m currently using butterfly, and trying to understand how it works and which kind of calculation and results we can get from the scripts.
So I started to work on the example files, but after your webinars I get confused. I cannot understand what is the purpose of the example file “Indoor_airflow” if we can do a natural ventilation calculation in using the “outdoor_airflow” script.
So my question is, when should we run an indoor airflow simulation instead of an outdoor airflow simulation where a natural ventilated building is designed?
Thanking you in advance for your help,
Mathilde.
