Looking at the name_#.ill files after an annualSimulation… on my machine there is an “name_space_0.ill” file, which looks like a merge of all the other .ill files. I was counting on this so I didn’t have to do the merging myself (for some work I’m doing). However, the same Rhino + Grasshopper file on another machine, seems to not be generating the merged “_space” file.
Why is that?
Is that due to some change that we made, or is that merged file not always created?
Off the top of my head, I’m thinking the 8 .ill files are because we are running it on 8 cores. So there must be a merge at some point, which I assume is the “_space” file.
I wonder why it’s not on the other machine… Could it be named something different? Of did the process fail before merging it to that specific file I wonder…
Honeybee separated input test points into several files based on the input for number of CPUs, once the analysis is over merges them back into _space_%d for each space. In your case you have only one space and so all the files are merged into a single ill file.
