You’re welcome - I realised I linked the UK version, there’s also a global version here:
I have a GitHub repo that has a script for morphing weather files using CMIP6 data following the existing methodology. It’s a bit complex to use, but if you clone the repo, fill in the config file correctly, and run the main script it works. In a few months I will be releasing a web app version for public use though.
Hi @mostapha
In Norway we have recently received an updated set of standardized climate files that have a bit more quality control than the TMYx files from OneBuilding.org
They are available here: TMY files for Norway based on CERRA data from 1991-2020
If you think it’s useful to add them to the map ![]()
Also 15 year TMYs for Norway with datasheets and error maps, here
And the same team has just released a map of the Norwegian dataset.
