The result of my radiation analysis appears totally sprenkled and rough (–> images). Changing distance from base or grid didn’t do the trick. I used very simple elements for my geometry, mostly solids. Nonetheless, the result is not very satisfying.
What’s the reason for this?
Thanks for your reply! I tried that, down till it crashed but it didn’t really get much better.
Maybe you should hide the surfaces you are analyzing, so only the calculated surfaces are shown …?
that did the trick, thanks a lot!
And sorry for asking about such a beginner issue. : /
