Why is the font not displayed completely? Is there any solution to it? Is it necessary to set the option Settings of the interface
Your Rhino model tolerance isn’t low enough to resolve the text. You can either lower your Rhino model tolerance or you can go over to the new LBT plugin where this issue no longer exits (no matter what your tolerance is).
