Why LCA component does not apear in Grasshopper?
Thanks for your help.
@hoda if I’m not mistaken there hasn’t been an LCA component in the toolkit.
there are some other LCA tools like cardinal LCA and Tortuga on food4rhino though.
I would also plug another LCA component called Bombyx.
Hi. Thanks. I use Rhino 6. Do you know how to fix this error?
I install Rhino 6.34, I think it works. Bombyx
Hi. Thanks. I install it. But show this error. Can you help me to fix it? I use Rhino 6.
I insrall Rhino 6.34, I think it works. Why this component in example is red and not work?
I just want to clarify that this is not an LB-Tools plugin, so it is likely you will not find a solution within this forum.
Hi! Great that you tried it. I am not the developer of the library. I just use it. I am guessing though that it will not work with Rhino 6.
