Why my model does not recognize the window material
Hello everyone,
I have a model here, that is for sensitivity analysis. However, when I change the U values it is not making any change to the result. Can someone check my model please? @mostapha can you please help me with it?
BEM-M-All-LoD3-Shima.gh (733.5 KB)
@shima I think having the same name for the material and the construction may be causing the issue.
You didn’t internalize any of the geometry in the file you uploaded so I can’t really check if that will fix it, but I think that may be it is the cause of the issue
Hi @TrevorFedyna, sorry for the late reply. That get solved thank you!
Regards,
Shima
