There is something with your geometry. If you connect all of it to the geometry input, you get the analysis done. The window trimmed surfaces (Those with the hole punched) are the “guilty” ones.
Thanks, @AbrahamYezioro. I understood, but I don’t know why sometimes it gives an error (1. Solution exception:‘int’ object has no attribute ‘GetBoundingBox’) and sometimes it runs fine. Is there any bug associated with the ladybug component? And what could be the possible reasons for “Problem 2”.
@tarun0949,
I recreated your analysis geometry. It takes less than a minute to do that. And everything works. As @AbrahamYezioro mentioned, there were issues with your geometry. Sometimes the solutions are the simplest ones.
