Hello Community!!
I found a bit of trouble with doing an analysis for my thesis (m a beginner and i really dont know whats the problem) the roofs keep showing in blue, even tho its very impossible looking at the very hot nature of the weather, I tried importing and creating shapes within rhino but its still the same. I appreciate the help so much!!
You should hide the geometry in Rhino and disable preview the gh geometry preview. Only enable preview of heatmap
your answer helped me a lot to organize a lot of things, thank you so much for it!! but unfortunetly the problem still persists?
Hello @HelpPlz ! If you share your grasshopper definition someone might be able to help you. Refer to the Ladybug Tools Forum Guidelines so you can read a little more about how to prepare your file before uploading.
