Win32Exception - Daylight with Radiance Error
Hey lbt Team,
Rhino: 7.16
PYTHON: 3.7.9
RADIANCE 5.4a 2021-03-28 LBNL (5.4.947ea88a29)
LB version: 1.4.0
Im getting a weird Win3dException Error. A little background, I was running an sDA script which was working fine yesterday and for some reason today when I opened it up it did not work and this error popped up. I tried using the sample tutorial files to see whether i messed anything up but I get the same problem. Here is the error message:
Runtime error (Win32Exception): WindowsError
Traceback:
  line 439, in __init__, "C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\subprocess.py"
  line 316, in run, "C:\Users\karimd\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py"
  line 127, in script
Seems like im not allowed to upload attachments, but it’s in the
ladybug-tools-1-4-0\samples\honeybee-radiance folder honeybee-radiance titled annual_daylight.
Let me know if you need more info. Thanks!
Hey @Karim ,
It looks like somehow you lost access to run commands from Rhino. The part that is failing is the line of code where we actually start running the simulation:
Is this running on a machine controlled by an IT department? If so, you might have more luck if you install Ladybug Tools by using the free Pollination Grasshopper single-click installer:
The latest Pollination single-click installer puts the installation in “Program Files” by default, which can get around some of these IT restrictions.
