I’m attempting to build a park with an emphasis on scent. Here, I’m trying to manipulate the course of wind movement using masses of vegetation, landscape topology, and a river profile. I was curious if there was a way for me to do a thorough study using grasshopper methods.
@agorgeatthemountain For wind CFD analysis, you can use Butterfly.
For this analysis, you can use dragonfly and envi-met .
thank you for your prompt answer, I was wondering if you had come across a particular example that you could share with me, as I’m fairly new to the grasshopper itself, it could be of great help!!
Butterfly installation folder have some example file. Some video tutorial is available on YouTube, you can follow it.
