Im trying to make a windrose with other inputs (coming originally from an excel file, I pluged the values into a "Ladybug_create LB Header then...) than from an EPW file... The problem is, that it doesnt recognize the wind direction correctly (showing only wind from the north, not according to the input directions) - maybe the input does not recognize that the values represent degrees???
Same problem occurs when I plug the “wind direction” output of an EPW-file into a Panel and then plug it into the wind direction input of the windrose. How can I solve this problem?
Maybe someone can help, would be great!
Unfortunately as a new user of this forum, it tells me that I cannot attach the file…
flozpunkt
