How does Honeybee determine the Height Difference
parameter of the WindandStackOpenArea
objects?
Looking at the IDF file, it appears that:
- Honeybee defines one
object for each exterior wall (i.e. if there are several windows on that wall, Honeybee considers them as one) - For the height difference to the neutral plane, it uses the height of the bounding box of the windows of a given wall:
Is this correct, and if so, what is the rationale?
