Hi
I have a detailed window which I modelled in Window (because I have three panes with argon and so I can’t model it directly in Honeybee). When I import it with the WindowIDFreport component all is fine until I try to run an energy simulation and then I get this severe error:
** Severe ** [WindowMaterial:GasMixture][GAP_107_W_0_0150][gas_1_type] - “Air - EN673” - Failed to match against any enum values.
** Severe ** [WindowMaterial:GasMixture][GAP_107_W_0_0150][gas_2_type] - “Argon - EN673” - Failed to match against any enum values.
Does anyone know why this is the case? Is it an issue with versions (both of Window and E+)?
Any help would be great!
Ellika
