good evening:
iam working on simple model and an error appered to me while i am generate window shading.
this error appeared while i am changing the number of shading from 2 to any higher value. I hope you to know how i fix it
Thank you
sim03.gh (629 KB)
devang
December 10, 2016, 12:55pm
2
Could you share the file please? I could take a look.
-Devang
Hi , First, Thank you for fast response I attached it in the discussion.
devang
December 11, 2016, 3:45am
4
Needed to update the component. Works now.
-Devang
sim03.gh (629 KB)
Thank you bro it is really working now but i have another answer if you have time to reply if i have different shading pattern and i wanna make it as shading object . which component will be suitable for this proces
devang
December 11, 2016, 2:26pm
6
Hi Ahmed,
If you have custom shading object and want to test its use then you may look into Honeybee_Ep Context Surfaces.
If you want to test shading options in Honeybee, then you may look into Honeybee_Energy Shade Benefit Evaluator.
For any studies involving testing of multiple shading designs, my first choice would be Ladybug_Comfort Shade Benefit Evaluator.
Regards
-Devang
