Hi Folks
Looking for help installing OpenFoam so it runs on a Windows 10 machine.
Have installed the butterfly/OpenFoam combo on my machine at work - Windows 7, with no real problem. Followed procedure here: http://www.openfoam.com/download/install-binary-windows.php
This I found by following the instructions here:
https://github.com/ladybug-tools/butterfly/wiki/Getting-started-wit…
HOWEVER:
At home here on my newer, faster Windows 10 machine - no such luck. This is becoming quite frustrating as I feel I am failing some obscure intelligence test.
I have attached what I suspect is the likely problem identifier - not that it has helped me identify the fix. What I believe is the salient message is appears in the OF_Env_Create Powershell Window (Running as Administrator) , which is step 3 on the Windows 10 special instructions found here:
https://github.com/ladybug-tools/butterfly/wiki/Windows-10-Installa…
The message (in red as can be seen in the attached picture) states:
Set-ExecutionPolicy : Windows PowerShell updated your execution policy successfully, but the setting is overridden by a policy defined at a more specific scope. Due to the override, your shell will retain its current effective execution policy of “Unrestricted”. Type “Get-ExecutionPolicy -List” to view your execution policy settings. For more information , please see “Get-Help Set-ExecutionPolicy.”
At C:\Users\Michael\AppData\Local\Temp\Quest Software\PowerGUI\18d7ce54-562c-4f2b-b985-3c24b83cae50\of_create_container.ps1:1 char:20
+ Set-ExecutionPolicy bypass
+ CategoryInfo : PermissionDenied: (
[Set-ExecutionPolicy], SecurityException
+ FullyQualifiedErrorId : ExecutionPolicyOverride,Microsoft.PowerShell.Commands.SetExecutionPolicyCommand
M
