Windows 11 Smart App Control blocks unsigned Honeybee Radiance executables (Ladybug Tools 1.10.0)
Hello Ladybug Tools team,
I am using Rhino 8, Grasshopper and Ladybug Tools 1.10.0 on Windows 11 for an architectural daylight simulation research project.
I am currently preparing an annual daylight simulation for a 600 m² office model using the HB Annual Daylight component.
1. Problem
Windows Smart App Control is currently enabled on my computer.
When attempting to execute Honeybee Radiance, Windows previously generated Code Integrity event ID 3077, indicating that the application was blocked by the enforced application control policy.
The policy name recorded in the previous audit was VerifiedAndReputableDesktop.
2. Executable signature verification
I checked the Authenticode signatures of the relevant executables using PowerShell:
Executable Signature status
honeybee-radiance.exe NotSigned
python.exe Valid
rtrace.exe NotSigned
gendaymtx.exe NotSigned
Relevant SHA256 hashes:
  • honeybee-radiance.exe: 9C2902714010B44C4467B54F49C4C501BAC998F8BD4F1A7D44B7D14D62CAC160
  • rtrace.exe: 12389659EADFF349F28EA65CB71B1D1F4F7C406C1C9474600D2536DB42CC8451
  • gendaymtx.exe: 5B0D773D104DBC91EC6B7FA7932AAEBEE26E0A2CD7331B00B2461043A2BDEDE3
3. Software environment
  • Windows 11
  • Rhino 8
  • Ladybug Tools 1.10.0
  • Python 3.13.14
  • honeybee-radiance 1.66.296
  • honeybee-radiance-command 1.23.0
  • honeybee-radiance-folder 2.11.17
  • honeybee-radiance-postprocess 0.5.22
  • Radiance 5.4 (2023-11)
4. Questions
  1. Is it expected that these Honeybee Radiance and Radiance executables are distributed without Authenticode signatures?
  2. Is there an officially supported, digitally signed version or installation method compatible with Windows 11 Smart App Control?
  3. Is there a recommended way to verify the authenticity and integrity of these executables?
  4. What is the recommended solution for users who want to keep Windows Smart App Control enabled while running Honeybee annual daylight simulations?
I would prefer to keep Windows security protections enabled rather than disable Smart App Control.
Thank you for your help!
Hi @huangliwen6636, the fastest solution would probably be to use a virtual machine if you really want too keep SAC on.
Everything on your list of programs being blocked due to lack of cert/signature, are open source. You could literally compile the *.exe’s yourself and add signature/cert.
you could try in powershell something like:
$cert = New-SelfSignedCertificate -Type CodeSigningCert -Subject "CN=MyLocalDev" -CertStoreLocation Cert:\CurrentUser\My
Set-AuthenticodeSignature -FilePath "C:\path\to\honeybee-radiance.exe" -Certificate $cert -TimestampServer "http://timestamp.digicert.com" -HashAlgorithm SHA256
to verify:
$Get-AuthenticodeSignature "C:\path\to\honeybee-radiance.exe"
But I think SAC will block that action but if you try similar shell command make sure you are running it as admin.
Hi @huangliwen6636,
We have received a couple of other similar requests. This is a problematic issue, and we would like to address it, but it will not be easy because we don’t own or create all the files listed above to be able to sign them.
From the list above only honeybee-radiance.exe is a Ladybug Tools generated file. ratrace and gendaymtx are part of Radiance that is not maintained by us. I will reach out to Greg at some point to see what would be his recommendation.
