I am not sure if I understand the request. Do you mean that initial radiation should be calculated based on input Rhino geometry or should it somehow try to use the LiDar geometry data that mapDwell does? (Note that it is often difficult to obtain LiDar data outside the US and my experience has taught me that most governments outside the US are not very open with their GIS data).
Also, it is very difficult to know what the tax credits and cost of panel installation are since it varies a lot from location to location. As I understand it these days, for every Watt of PV installed, around $0.80 is for manufacturing and somewhere between $2.20 and $3.20 is for shipping and installation.
If you know of a good global database with good estimators of labor installation costs and tax credits, let us know and we can try to link to it but I feel that Mapdwell would probably be using such a database if it existed.
Thank you very much for taking the time to look into this once again.
I want to reply with an example of the potential workflow, but the GenCumulativeSkyMtx is giving me a fatal error so I can t run the GH.
(I don t mean replicating the Mapdwell, I just reference it as an example of possible assumption inputs regarding costs, type of PV, frame or not, or anything else (I currently lack the knowledge on the subject) that someone would need to vary in order to estimate PV related outputs: returns, payback cycles etc. The input geometry will be our designed in Rhino PV surfaces, with Radiation values calculated from LB).
Any suggestions for this error? When I have this running I will send a GH regarding the PVs.
Thanks for the clarification about the PV request and I’m sorry to have given so much pushback. Climate and energy are complex sciences where it can be difficult to get accurate results but they seem to pale in comparison to economics. Hopefully, someday we get databases of economic data that can match the usefulness that we pull from the DOE’s climate database and, until then, it seems the best we can do is make our own GH definitions from what we find in our own localities and times in history.
The error seems to be happening because of your Ladybug Default Folder. Do you have LB_LB flying and, if so, what is your default folder?
I understand the complexity including costs to inputs and outputs but could be a very exciting future extension of LB/HB.
To further the conversation on such a potential component/s I attach some images and a GH of a (obviously very very ambitious) dummy component with potential inputs and outputs.
Economic related inputs could be plugged in manually, corresponding to project specific needs, contractual agreements, locality specifics etc etc.
Of course what I am proposing could be completely unrealistic…
Hi, I agree with Dimitrios. The PV-economics component would be of huge help to convince clients to install them, even if you have to input some economics and technical info from the PVs yourself.
