We are trying to run the 2 phase daylighting script with a similar method to your file above. We are assuming 2 states - One with a translucent modifier for blinds over the aperture group and One with the blinds open. When we run the daylight simulation without the Enhanced 2-phase method, the run annual daylight component runs smoothly and provides an output result. However, the Post processing component AnnualtoData fails as its not able to find the required files to convert to data.
The results folder doesnt contain .ill files as seen in the image. However, the .ill files are generated in another sub folder under the Annual Daylight folder.
- I’ve check for permission issues but there seems to be none.
- I have run Rhino as an Administrator just to check if there are any access issues.
- I’ve tried copying the .ill files and sun up hours text file into another folder and providing that input using a Readfile component. It does not seem to work.
- Checked for white space in file path
Daylight_sDA_LEED_Option1.gh (574.4 KB)
Ive attached the file in case you need to have a look.
Thankyou so much for your amazing work with this.
