I am trying to model a rectangulare space covered by a wavy roof canopy. Specifically, HoneyBee struggles planarising that through its (I guess) triangulation algorithm.
Building the thermal zone through HB Faces → HB Room results in a number of gaps which prevent from running a thermal analysis and seem to corrupt the daylight figures too.
Using a HB Room from Solid, having previously joined the breps, gives better results.
What simplification / meshification procedure would you suggest, to simplify the curved surface prior to feeding it into HB? I am looking for something that could allow the big space to be sliced vertically (to create thermal zoning through airwalls) as well as a roof tessellation that could allow individual faces to be passed as HB apertures (ie rooflights) but NOT using the SkylightsbyRatio component.
LBTForum__NIC__v1.1.0.gh (196.6 KB)
