@javiervinuales As I know, it is hard to change the default folder in Grasshopper. Maybe you should change the python code of butterfly.
You can change the code as below.
The abspath is C:\Users\XXX\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\butterfly\case.py
