Hi everybody,
i have got a question regarding the type of surfaces which i think create some problem for the simulation.
As you can see from the image below (sorry for the italian names) there are two different types of planar surfaces:
1 - the surface in which all the segments are into the geometry
2 - the surface in which not all the segments are into the geometry
This second one is the one that i think it is creating me a lot of troubles.
Indeed, looking at my workflow in gh, even though i have a closed zone (from the component create HB zone) the simulation continuosly crashes with thousands of errors that i really don´t understand, like “surface non-planar” (which is impossible because i have checked through the label zone surfaces component and all are planar).
So my question are: am i right regarding this kind of issues due to the shape of the geometry? is it possible?
In that case, is there a way in gh/rhino to “explode the surfaces” to create correct shapes for the simulation?
Thanks a lot in advance
Claudia
