Hi everyone,
my colleagues and I tried to run a daylight autonomy simulation in a shoe box shape room and it worked…
Now that we are applying the same script to a bigger scale building, composed of more complex geometries, nothing works anymore and the output is weird: every test point has the same value (97% DA) and it’s impossible to visualize these values even if a text tag 3D is assigned to points (check Result.jpg)
The output that we get is a uniform mesh.
To check this output we also run an illuminance analysis using the same test surface, giving 300lux as high and low bound and some areas didn’t reach the target value - which means that there must be some areas below that threshold.
Another thing: as you can see from Screenshot.jpg at one point we get the string saying *.dgp not found. Is that a problem?
Attached you can find the Grasshopper file.
Thank you all!
Simone
Daylight Autonomy Simulation.gh (755 KB)
