Dear community, dear sir Roudsari, sir Mackey and sir Devang,
I noticed that from component RADParameters, when I start a DF simulation, the -ar parameter is always 300 (see the cmd window) and it does not change even if I change its value.
I don´t know if it’s an error or not.
Best Regards
Hi,@gaetano.christian.ruvio I think you should check RADParameters component’s output before running Radiance simulation.
Hallo sir Ming,
The value in the output is correct, but only for the -ar value, it is not congruent with the cmd window.
Honeybee adjusts the values if the values are too low. Check the Readme output of Run Daylight Simulation component.
Thanks for the answer sir Mostapha, the 0 for the -ar parameter is not a low value, but the better value for a accureted simulation.
Good point! This should fix it.
Thanks for your precious job sir Mostapha!!!
Greetings from Munich
