Is there any components to attach coils for a WSHP to the airloop of a DOAS system serving multiple zones to control the temperature of the incoming air (instead of just being able to attach the WSHPs as zone equipment?)
Hi @Elliot_Glassman, I think you are looking for central heat pump. You can reference the template “GSHP_Central Heat Pump” but without ground heat exchanger.
Thanks, Mingbo. A follow up question: How would you connect the central heat pump to the DOAS air system… do conventional water coils go on the DOAS unit from the chilled and hot water loops?
I assume this is an abstraction because in reality there are no chilled water loops but the DX coils are directly on the DOAS but using the HP condenser loop for heat rejection.
