Hello, dear forum. I have a problem with WWR in my algorithm. once I run the energy and light simulation, with changing variables one by one it works. but when I run optimization with Wallacei, it errors. I have checked and understand that the error happens because of my WWR algorithm. Is there anyone who knows the problem?
Also using LBT 1.xx (the new release) instead of the legacy tools with Wallacei: will make for notably more efficient simulations; the LBT crew did a fantastic job optimizing the full release vs the legacy release.
Thank you @TrevorFedyna for checking the algorithm. I changed the WWR from 100% to 90% (and 70-50%) before. but the errors remain. When I remove the WWR from the genes of wallacei (optimizer) it works properly. I have the same problem with a few other shadings.
another problem happened when I update my Rhino6 for using wallacei, energy, and daylight simulation don’t run correctly (even the files which run correctly before updating the Rhino 6). I did not reinstall any of my plugins after updating Rhino. Could this be the cause of the problem?
(I have to learn LBT at the proper time cause I know it solves a lot of problems but I have to solve my problems for a university project as soon as possible).
-Sima
I’m making a wallacei orientation/glazing-ratio/shading optimization script for fun; and to share on another platform; I’ll attach it here when I’m done incase it can answer your questions better than I
