I have an installation issue:
Step 1 works well. In step 2, when toggling True, after some successful steps, the component returns an error.
{0;0}
0. Installing Ladybug Tools core Python libraries.
Installing lbt-dragonfly==0.8.105 via pip using
C:\Users\Użytkownik\ladybug_tools\python\python.exe -
Ladybug Tools core Python libraries successfully installed!
Installing Ladybug Tools recipes.
Installing lbt-recipes==0.17.10 via pip using
Ladybug Tools recipes successfully installed!
Installing ladybug-rhino Python library.
Installing ladybug-rhino==1.31.3 via pip using
Ladybug-rhino Python library successfully installed!
Successfully set Python search path to: C:\Users\Użytkownik\ladybug_tools\python\Lib\site-packages
Runtime error (EncoderFallbackException): ‘ascii’ codec can’t encode character ‘\u17C’ in position 14: ordinal not in range(128)
Traceback:
line 311, in write_iron_python_batch_file, “”
line 505, in script
Thank you in advance for your reply.
