1. Solution exception: Failed to import honeybee: No module named honeybee.room
hi, yesterday I installed ladybug tools correctly but now when I want to create a room by HB room from solid I got this error>>>>>1. Solution exception:
Check if the same is true with Ladybug components. If yes, that means the LB tools are not added to the Rhino Python path. Follow the discussion to resolve the issue.
thank you i fixed it
