3 HVAC Systems in Ironbug in energy simulation
Hi ,
I’m just a beginer of ironbug and found a problem, that I can’t add more than 2 HVAC systems from ironbug to “HB run OSM”, which can cause a failure.
Is that the limit of software or I just make some mistakes?
Thanks for your help!
The gh file is attached below.
Test-3 ironbug system-bug.gh (306.1 KB)
@ MingboPengIs there any idea about this problem? Thanks
Hi @YZZhang,
One model can only have one “HVACSystem”, you just need to merge all “AirLoop” and “PlantLoop” together.
