i’m trying to run a 5-phase-simulation, starting with the examplefile 12_five_phase_II_gridbased.gh
If i use the 0.0.04 files from github with the latest installable version, also 0.0.04 (downloaded from food4rhino) everything seems fine, but after running the simulation i get an error “1. Solution exception:invalid literal for float(): FORMAT=ascii”
Found 6 opaque surfaces.
Found 2 fenestration surfaces.
Found 2 window-groups.
[0] south_window, 2 states.
[1] skylight, 1 state.
Writing recipe contents to: c:\ladybug\honeybee004\gridbased_fivephase
Copying clear.xml to c:\ladybug\honeybee004\gridbased_fivephase\scene\bsdf
Copying diffuse50.xml to c:\ladybug\honeybee004\gridbased_fivephase\scene\bsdf
One file from the radiance scene is added to the analysis.
Copying context.rad to c:\ladybug\honeybee004\gridbased_fivephase\scene\extra
Reusing sun_matrix: sunmtx_vis_107380_48.68_9.22_0.0.mtx.
Unloading the current values from the analysis grids.
loading total and direct results for room_w_skylight AnalysisGrid from scene::default
c:\ladybug\honeybee004\gridbased_fivephase\result/scene..default.ill
c:\ladybug\honeybee004\gridbased_fivephase\result\sun..scene..default.ill
Runtime error (ValueErrorException): invalid literal for float(): FORMAT=ascii
Traceback:
line 325, in <genexpr>, "C:\Users\hw\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\analysisgrid.py"
line 326, in <genexpr>, "C:\Users\hw\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\analysisgrid.py"
line 343, in set_coupled_values_from_file, "C:\Users\hw\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\analysisgrid.py"
line 337, in results, "C:\Users\hw\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee\radiance\recipe\daylightcoeff\gridbased.py"
line 69, in script
Can anybode give me an advise?
Best regards,
Heiko
