I’m relatively new to ladybug / honeybee, and cant seem to figure out a solution to my problem.
Trying to generate a Annual climate-based grid-based UDI, i can’t get any results. The only fauilt i find, is in “Ladybug _ Recolor mesh”:
“1. length of the results [=1] is not equal to the number of mesh faces [=98] or mesh vertices[=120].”
Using the same definition to generate point-in-time works fine, and i think the components are updated…
Welcome to the forum. This has been asked before. Please check this discussion. Please also read Forum guidelines. It would be great it you also set a profile picture.
Sorry, it seems thst me and @walaa didn’t have the same issue. I tried follow the instructions she got, but without success. My input/analysis result going into the Recolor_mesh reads “null” and when I trace it back to LookupFolder_Daylighting, im lost…
