Dear @mikkel,
If I can afford, I would have a request to implement the script and a question about one component.
Having already the possibility of being able to analyze so many sensors and directions at the same time, in my opinion would be optimal, to be able to extrapolate the values for example of a single direction (per example the point 80) directly in the _readImagelssGlare component.
At the moment to do it, I need to read and extrapolate from the file “views…scene…default”, the string with the values of the desired sensor, save and convert it so that it is readable in GH.
I can understand that it can be complicated, but in my opinion it would be a great addition.
I have a question about the sGA value.
I can’t understand the decimal handling of the value.
If the Treshold is 5% (right according to the EN 17037), why your input is 0.05?
Shouldn’t the final result be 6% and not 0.6?, ie that 6% of the occupied hours has a DGP greater than 0.45, and in this case is 1% over the treshold?
I don’t wish I misunderstood something
Thanks for all
Greetings
