What is the easiest way to add the field: Carbon Dioxide Generation Rate to an existing People EP object? I can add entire objects with add_str_ but have not figured out how to append fields to an object that already exists.
If you are looking for an automated solution, this is probably done most easily by editing the output OSM using the OpenStudio SDK and workflow described here:
You’ll just have to use the OpenStudio SDK to get the People Definitions and set the carbon dioxide level.
