Hi there,
I am trying to analyze a PV module installation and I would like to specify the properties of my own set of PV panels. By default, the material assigned in SimplifiedPhotovoltaicsModule is c-Si while the ones I’m studying use CIGS technology. Is there a way around that?
I also tried using ImportCECPhotovoltaicsModule or ImportSandiaPhotovoltaicsModule and see if there was something similar to what I need there but the website doesn’t seem to work. (Also checked what was said in this topic, but the website didn’t work either)
So any help would be much appreciated
