The import (Photo voltaic) components + How to change the PV module material
Hi guys …
I am trying to use the import “ImportCECPhotovoltaicsModule” or the other one “ImportSandiaPhotovoltaicsModule” … but the site indicated does not work …
sam.nrel.gov/libraries
Moreover, is there a way to change the PV module material in the PV simplified settings module … its defauls is crystalline silicon (c-Si), as indicated.
Thanks …
The correct site: https://sam.nrel.gov/libraries
