I have facing the same problem with “ModelToOSM”.
I’m sure it’s something inside my EPW file but I can’t find it.
I have tried to lock manually for the non unicode character, as solved in this closer situation.
Continuing the discussion from Color zones and surfaces by EP results - Unable to translate bytes:
My error message:
Runtime error (DecoderFallbackException): Não é possível converter bytes [C9] em índice 46 da página de código especificada para Unicode.
Unable to translate bytes [C9] at index 46 from specified code page to Unicode (translated)
Traceback:
line 390, in _iterencode_dict, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 434, in iterencode, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 47, in py_encode_basestring_ascii, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 189, in dump, "C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json_init.py"
line 150, in to_openstudio_osw, “C:\Users\guilh\ladybug_tools\python\Lib\site-packages\honeybee_energy\run.py”
line 212, in script
Thanks for your attention.
