still haven’t managed to get any of them connected to colibri, would appreciate your thoughts on which method would work better and any suggestions to get them linked to Colibri so that my results are in line with the combination of design variables (window width, shading type…etc) that is running in colibri??
Thanks a lot @devang
Just tried this, it seemed to record the data at first. gave an output of different columns as I wanted but i can’t tell which combination of parameters (i.e. sliders) is for which output. I mean i get the results but not the input. noting that I’m having multiple sliders.
is there a way to link this to colibri iterator so I know what the inputs are?
another scenario is the idf different namings as i explained in this screenshot, but then how would you iterate that in line with colibri?
Hard to precisely respond But I would suggest you use the native grasshopper concatenate component. That should allow you to write all sorts of data such as inputs, file names, etc.
