after the update of LBT 1.1.0 to the 1.1.1, there seem to be problems with the component HBDaylight Factor.
This error come from the HBRunRecipe Output:
If I go back, thanks to the LBversioner, to the vers. 1.1.0, I return to have no problems.
Same problem, tested on 2 different Models and on 2 different computers.
thanks for replying.
Yes, I assumed that I had also updated the components.
I updated again all, to the ver 1.1.1, and manually insert the new components, but the problem remained.
I attached the file LBT-DaylightFactorError_v1.1.1.gh (1.0 MB)
I remember, that the problem returns on 2 different computers.
I have no experience in that programming language, so I cannot understand what could be the cause of the error.
I also tried to step bag to LBT version 1.1.0.
First I ended like the picture shown below but HBRunRecipe component also contained the hint âFailed to find C:\Users[User].queenbee\config.ymlâ
After a restart it was gone and things look like shown.
Usage: queenbee luigi translate [OPTIONS] RECIPE [PROJECT_FOLDER]
Try âqueenbee luigi translate --helpâ for help.
Error: Invalid value for âRECIPEâ: Path âC:\Users[User]\ladybug_tools\resources\recipes\honeybee_radiance_recipe\annual_daylight.yamlâ does not exist.
When you return from the 1.1.1 to the 1.1.0v, you should restart Rhino, load a new LBVersioner, and play again with the 1.1.0 imput. Than resync the GH components.
Try it, should work.
For the rest we are waiting the admin, who will surely be busy under work, for the new stable release.
