Hello thogether
trying to move on from legacy to new LBT, I tried to build a simple simulation.
At the moment I have no idea why I get this message.
Runtime error (Win32Exception): WindowsError
Traceback:
line 435, in init , “C:\Program Files\Rhino 6\Plug-ins\IronPython\Lib\subprocess.py”
line 127, in script
Any idea why?
Honeybee Lwh 002.gh (56.4 KB)
Martin
I have exactly similar case. Previously everything just work fine. This morning, when I simulated for DF and Annual Recipe it returned error. Hope there will be a response for a solution.
Btw, It is working now when I return to LBT 1.1.0. Just use your Versioner LBT component to do so.
Hello atthaillahb
the tread was pulled to and continued a bit in this thread
Dear @chris ,
after the update of LBT 1.1.0 to the 1.1.1, there seem to be problems with the component HBDaylight Factor.
This error come from the HBRunRecipe Output:
[DF_error_LBT1.1.1] .
If I go back, thanks to the LBversioner, to the vers. 1.1.0, I return to have no problems.
Same problem, tested on 2 different Models and on 2 different computers.
Greetings
After some back and forth updating it is working for me with the latest update.
Thank you for your help
Best regards
Martin
