Daylight saving period for Radiance and rad parameters
Hi @mostapha
In this post : Daylight Saving Time. Analysis Period
you mentionned that we could specify the daylight saving periods for annual daylighting analysis, but I can’t find this possibility anywhere… Is it available in Honneybee legacy ?
Chhers,
Vincent
Still not possible.
You should double check Daysim’s document which is what the legacy plugin uses for annual daylight simulation but as far as I can remember the dates for daylight saving period are hard-coded.
