Hello -
I’m trying the DC image-based recipe for the first time. I’ve previously only used the DC grid-based simulation and had no issues. I get the following error:
Found 2383 opaque surfaces.
Found 26 fenestration surfaces.
Found 1 window-groups.
[0] ext_glaz, 1 state.
Writing recipe contents to: c:\ladybug\30VN_intp1_test\imagebased_daylightcoeff
Runtime error (ArgumentTypeException): write() takes at most 3 arguments (4 given)
Traceback:
line 928, in skymtx_to_gendaymtx, "C:\Users\MG\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee_plus\radiance\recipe\recipedcutil.py"
line 120, in get_commands_sky, "C:\Users\MG\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee_plus\radiance\recipe\recipedcutil.py"
line 62, in script
line 198, in write_wea, "C:\Users\MG\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee_plus\radiance\sky\skymatrix.py"
line 238, in write, "C:\Users\MG\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts\honeybee_plus\radiance\recipe\daylightcoeff\imagebased.py"
I tried to run the DC image-based HB+ sample file and got the same error. I also tried it on a different machine and got the same error.
Any advice would be appreciated. Thank you!
Maria
