Design Explorer - Unreliable
hi,@AbrahamYezioro
I believe the program only allows F11 to toggle full-screen mode. ASince I’ve implemented a very simple encapsulation approach, I might not be able to make further modifications to Electron. If repeatedly pressing F11 still fails to switch display modes, I’ll investigate this issue in depth.
I see what you mean now. Just thinking about it makes me spot several potential bugs. I think we should keep things as they are. :skull:
This issue is actually quite challenging to address, as the data parallel plot ultimately requires a series of numerical mappings. Your report has also made me realize that not all data variables are necessarily numerical. I’ll start by attempting to resolve them.
Hi @ZhengrongTao ,
Shame on me. This is the option I didn’t try. It works just fine. F11 toggles to FullScreen and back. So no issue here. Sorry.
Yes. It is important. If taking the legend out helps to solve this issue I suggest to do so. It is a nice to have but no so important, at least not as much as having non numerical data.
Thanks!!
Hi, @AbrahamYezioro
I’ve resolved most of the issues, and you can see the improvements in the latest version.
Release v1.1.0 · LoftyTao/design-explorer-react
In this version, all non-numeric data will be ignored during rendering, though it remains accessible in the data tables.
In addition, I made some layout and interaction optimizations, tweaking a few minor details. I believe we can go at least a month or two without needing further modifications. :grinning:
You can conduct further testing. If there are no major issues, I believe it can be recommended to other forum users.
best.
Zhengrong
Hi @ZhengrongTao ,
Very nice!
OK. But let’s not forget it :wink:
No major issues at all. This version is good to be recommended as is.
Some comments though:
If possible to make the color of the picked solution to be the same as it’s original one will be nice.
I rather put the images below the graph and not below the table. It is easier to link the image with the selection, than with the row in the table. Maybe this is just for me …
I’m picky here: If possible to color the text of the inputs/outputs differently [I mean the titles in the graph].
That’s what I have for now.
Want to thank you again for your great job and effort here.
@AbrahamYezioro
I added these requests in the beta version of v1.2.0. Although it was a bit faster and simpler than I expected, I currently don’t have time to conduct the tests. You can give it a try for me.
I hope to direct the discussion of the new Design Explorer to this new post, so that new users can follow my subsequent improvements.
best.
Zhengrong
Will do soon. I’ll respond in the new thread.
Thanks @ZhengrongTao !!
